I have a Voltage. While we love it, it's not without issues. The ramp is pretty steep and always a challenge to get my Harley in and out and if the tramp is wet, or the ground is wet, it's impossible because it is so slick.
Quality control on today's trailers is pretty much non-existant. I've had to redo the A/C duct-work taping because the tape rolled up into a ball, Had a water leak in the main slide roof, the main TV mount had just one screw holding everything to the wall, the water plumbing had construction crud in it that glogged the faucets, the Schwintek slide failed (stay far away from Schwintek), the plywood under the master bed was cut 8 inches too narrow to properly support the mattress, the tires are made in China and are terrible, the coax cable had splitters that were not up to the task for satellite tv even though the system was made for it. Your experience may vary, lol.
