AKinLA wrote:
Thanks again for the help,
The truck is a 2016 F-250 4X4 with a 6.7L power stroke diesel platinum edition with tow package and ready for 5th wheel hitch to be bolted in. Its rated for 14,000 lbs conventional and 15,100 lbsgooseneck.
The trailer is 10,600 dry and with the tanks if full adds another 1400, I'd will be close to the limits of weight for the truck if using the 20% (12,080 lbs). Is this too close? Will the truck be a dog going down the road?
You should be "good to go":)...You don't necessarily have to fill fresh water tank up, unless you're boon docking. If loaded to max GVW of 5er, You could hit 2800# with pin weight. Truck should tow OK.
