Cummins12V98
Dec 23, 2021Explorer III
Advertise the hitch at the lowest 50% of new on Craigs list. Try higher if you want.
I have owned both hitches you mention. They are both great IMHO. The puck hitch will cost more and is rated to tow more weight @ 25k . The The GooseNeck unit is rated at 20k and the head for both are exactly the same. The base is lighter on the 20k.
So since your truck has the pucks I would stick with that system simply because you may want a larger RV some day.
About Fifth Wheel Group
