humblerb
Dec 23, 2021Explorer
laknox wrote:
I'm not sure if B&W has a version to use the OEM GN hitch, only the puck version. AFAIK, all the OEM GN hitches use a round post for the GN ball, where the Companion uses a square post. Also, the "standard" Companion is rated for a max of 20,000 lbs whereas the puck version can be had in 20k and 25k versions, for a Ford.
Lyle
I've owned my first truck with pucks for 24 hours now.
My truck's GN hole is round.
I did notice the B&W post is square.
If most OEM are round, when or how would someone use the square post?
Why does B&W make square when most trucks are round?
Sounds like I need to just go with the 4 pucks.
About Fifth Wheel Group
