opnspaces
Aug 27, 2023Navigator III
I use plumbers silicon lube to hold the seals in place for assembly. If you are worried about the grease trapping particles think about gravity and just don't grease the bottom 1/3rd of the seal. But seriously the grease is not going to hurt anything. And the grease will allow you to slide the valve into the joint without dislodging the O-rings.
As said leave the white section alone unless you want to create a leak. Just scrape the bolt heads clean. And no you do not have to reapply the goop that you scrape off.
About Fifth Wheel Group
