Bedlam
Nov 12, 2014Moderator
The shipping weight + carrying capacity will be the GVWR of the toyhauler. Use this number as the worst case for all your calculations. Pin weight will be 20-25% of the GVW, so now you know that you need a truck that can pull 16,500 lbs and has a payload capacity sufficient to haul your family, gear, hitch and 4125 lbs of pin weight.
For this toy hauler, I would expect 8000 lbs on your rear axle once you are hitched and loaded and GCW around 24,500 lbs.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
