cchristanis
Nov 12, 2014Explorer
Just a minute cause if you go on rams towing guide and look at their tradesman 6.7 3500 with 3.42 gearing it has a 17000 pound capacity. Now u change the gearing to 4.10 and it jumps to 30000 pounds! I know its not the same truck, but thats quite a difference to me!
N-Trouble wrote:cchristanis wrote:
Gearing will make a difference (can be thousands of pounds) in his towing capacity , I know it wont for the payload. If you have a truck with 3.21 that can pull 8000 pounds and a truck with 3.92 that can pull 10000 pounds, I think thats something that needs to be considered... There are 2 variables in towing, not just payload. I didnt know the specs on the raptor or his truck as far as how much weight the TH was and how much he can pull. Thats all I was getting at.N-Trouble wrote:cchristanis wrote:
What kind of cab (Regular, Quad),....which model (tradesman, laramie, etc.), what gearing, Im assuming 3.42. Its not happening. New truck or different trailer.The gearing makes a huge difference.
Has nothing to do with gearing.. It's all about ACTUAL pin weight and real world payload you get with a 3/4 ton truck (regardless of brand).
If his TV were gas then yes gearing would absolutely be a factor. THe fact he has a 2014 Cummins, gearing is a non-issue. That motor will pull that trailer just fine regardless of gearing option. 3/4 ton payload and pin weight are the limiting factors at play here.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
