cchristanis
Nov 13, 2014Explorer
Which is exactly what I said.look at the ram site. My original point was gearing makes a difference even in diesels. You just showed that yourself.
otrfun wrote:cchristanis wrote:The 4.10 rear end alone doesn't get you the 30,000 lb. tow capacity. In order to reach 30,000 lbs. of tow capacity ya gotta have a Cummins Diesel, DRW (dual rear wheels), the $3000 Aisin tranny, and the 4.10 rear end. As far as I know, the only rear end available on the Cummins Ram 2500 and Cummins Ram 3500 SRW (single rear wheel) is the 3.42. The gasser 2500/3500's only have two rear end ratios available, the 3.73 and 4.10.
Just a minute cause if you go on rams towing guide and look at their tradesman 6.7 3500 with 3.42 it has a 17000 pound capacity. Now u change the gearing to 4.10 and it jumps to 30000 pounds! I know its not the same truck, but thats quite a difference to me!
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
