N-Trouble
Nov 14, 2014Explorer
cchristanis wrote:
Which is exactly what I said.look at the ram site. My original point was gearing makes a difference even in diesels. You just showed that yourself.otrfun wrote:cchristanis wrote:The 4.10 rear end alone doesn't get you the 30,000 lb. tow capacity. In order to reach 30,000 lbs. of tow capacity ya gotta have a Cummins Diesel, DRW (dual rear wheels), the $3000 Aisin tranny, and the 4.10 rear end. As far as I know, the only rear end available on the Cummins Ram 2500 and Cummins Ram 3500 SRW (single rear wheel) is the 3.42. The gasser 2500/3500's only have two rear end ratios available, the 3.73 and 4.10.
Just a minute cause if you go on rams towing guide and look at their tradesman 6.7 3500 with 3.42 it has a 17000 pound capacity. Now u change the gearing to 4.10 and it jumps to 30000 pounds! I know its not the same truck, but thats quite a difference to me!
Man just let it go... I don't know why your so stuck on the whole gearing thing. Everyone has already pointed out he's way overweight so why care about gearing at this point???
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
