roller183
Nov 23, 2014Explorer
Your truck will pull the load just fine. My 2013 2500 RAM is rated at 25,000 GCVWR as is yours.
We both have 3:42 rear gears. I put airbags on mine because I have leaf springs on the rear.
You, as 0f 2014 have coil springs. I dont know if you can do anything to assist the coils.( I have read that some have load leveling air bags on them.)
I put on 10 ply tires, 3750lbs per tire so mine was equal(7500lbs worth of tires) with the 3500 SRW.
Axles are the same 2500-3500 SRW, not dually. The RAM dually now has a 11.8"housing (38000 GVWRC) vs 11.5 for the stardard AAM(American Axle Manufacturer) RAM axle.
I cant find the spec on the unit you listed but that should give some more info to deal with.
About Fifth Wheel Group
19,040 PostsLatest Activity: Jul 08, 2013
