agesilaus
Nov 08, 2015Explorer III
color temp
As you can see from the table, sunlight is around 5000-6000K, I've seen 5700 K used. Some LED lamps will have a CRI rating (color rendering index) and the closer that is to 100 the closer that lamp is to real sunlight. Anything in the mid 90's is good. However a lot of people are used to incandescent lamps which have a distinctly yellow cast and so a bulb designed to match sunlight will seem to be blue to them.
All this comes down to what you like, if you are happier with 4500 K lamps then get them. I got a 5700 K 100 W bulb from Home Depot, Phillips brand, for $10 a few days ago. That's my price point.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
