MarkTwain
Nov 24, 2019Explorer
MarkTwain wrote:importman wrote:. Correction “I would NOT gamble on your decision!!!!
Hello Everyone, I have a rather unusual question. My 06 Montana 336rlt has been parked on a permanent site for about six months. But now due to repeated problems with leaks around some of the slides I’ve decided to put one of those metal carport style sheds over it. My problem is I need to move it about 3 feet in the curbside direction. There’s not enough room on the backside for the frame of the shed because of the location of the service pole and the pole can’t be moved due to a hill right behind it. Two things that are problems in moving it are that I don’t have a truck with a fifth wheel hitch and I don’t want to pull the slides in if I can help it. (I have new carpet with thicker padding that the slides snag on). So what I’m considering and I need opinions on is this. If I take it off the blocks and pump the tires up tight, how hard would it be to slide it about 3 feet. I would pull one end at a time using a winch or a come-along and some luckily well placed trees. I should add that the surface it’s on is dirt and some gravel and it’s hard enough that the tires haven’t sunk in. So what do you guys think? Will this work and if so how difficult will it be. Thanks in advance for any help you can give.
Sounds like a disaster waiting to happen:( I would be concerned about damaging/bending/knocking out of aliment the springs/axles/wheels. Trailers were not designed with the intent of sliding them sideways on the tires.
Options: 1. call a local RV shop which will have a truck with a 5th wheel hitch as they have to move trailers around the shops to work on them.
2. Call Good Sam and have them locate a tow truck Company who will come out and move your 5th wheel. In both cases, you will probably have to pay out of pocket.
3. Contact your local Elks RV Club and ask if one of the RV members will come and tow the trailer for you. A $50 tip would be in order. The possible costs of damages by sliding your 5th wheel sideways is a gamble I would want to take, but then again this America and everyone has a right to make their own decisions:)
About Fifth Wheel Group
