abc40kids's avatar
abc40kids
Question about my Hydraulic Resevoir
Just got this 2015 Mountaineer and noticed something last night while starting to put things in the camper. So all slides are in but 6 point level is down..... The Hydraulic resevoir has a fill line near the top but reservoir only has a few inches of fluid in it.
If I retracted the six point will it fill up that much? I probably should have done that before posting but just thought about the leveling being down.
  • The fluid level should be at the full line only when all Hydraulic operated items are retracted. If any of them are extended and you fill it to the full mark, expect a big mess when you retract everything!
  • Don't have a Level Up system, so I can't answer you on that. Have you tried the Montana Owner's Club forum? http://montanaadministrator.forumco.com/
  • I would retract the 4 rear levelers and then fill the reservoir to the line. "A few inches" is not very descriptive. Is it 3 or is it 9. Could make a big difference in this case.
