laknox
May 14, 2014Nomad
Scott_85 wrote:
When I get to the campground I've just been using one yellow pad or put under the landing gear and the rear jacks, then running the jacks all the way down, is this right or should I use more yellow pads? The reason I ask is because I can't seem to get the camper steady enough. I also use the x chocks. Is there anything else I can do just to make it a little more steady?
There are several companies that make stabilizer systems that significantly help reduce trailer movement. JT Strongarms and BAL are 2 that immediately come to mind. Many people use the same principle and build their own. Basically, you have a X of supports between the front legs, from the frame on one side to the foot on the other. Next, you have another support arm from the frame behind each landing leg to the foot of the leg. Third, you have support arms from the from to the foot of each rear stabilizer. Each support arm telescopes and has a locking screw to lock it up, once you're level. Some people have just put eye bolts through their frame and use ratchet straps to achieve the same thing. :-)
Lyle
About Fifth Wheel Group
