Vulcaneer
May 14, 2014Explorer
I lower the inner leg to 4" off the ground. Then lower then landing gear to get it level. The feet go on a 2X8. Then snug up the rear stabilizers. If you still get objection "bounce" put some of those cheap little screw jacks in front and behind the spring shackles on both side. And snug those up to.
The more expensive way is to get JT Strongarms installed. They work very well.
I never had much luck with King Pin Tripods.
About Fifth Wheel Group
