Okie1
May 14, 2014Explorer
Same here. Works great and very easy to install.
Campinfan wrote:
I use the BAL stabilizers and put two of them on each leg/jack. One goes along the front (or rear) of the rig and the other goes along the long side. that way they are set at about a 90 degree angle to each other. It stops the forward/backward movement, and the left to right movement. If you just use one, it only stops the movement in that direction. Maybe its overkill but it works
About Fifth Wheel Group
