stetwood
Nov 27, 2014Explorer
If you don't run your furnace, open your faucets to allow for expansion of any freezing water. For just 4 hours I would not be worried and run without furnace at 20 degrees. When you stop, turn on your pump and replace the water in the lines with warmer water from the fresh water tank. It should be a bit warmer due to mass.
About Fifth Wheel Group
