golf_bears
Dec 20, 2014Explorer
tvfrfireman, thanks for getting back to us.
I had the same problem and I had a Teflon disc between the hitch head and the pin box. Found out I needed more than the standard thickness (1/4" or 3/16" ??) thickness on the Teflon plate. I ended up putting two Teflon plates in, one older one slightly worn down and a new one. Solved the problem for me.
I think Hensley sells a thicker Teflon plate to deal with this problem. Call and ask them.
Also, as suggested, make sure the rail bolts are torque up properly, I think 75 ft-lbs is the right number.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
