JTrac
Dec 21, 2014Explorer
crcr wrote:pcm1959 wrote:
I have been going through the same issue ever since I've owned the Hensley BD3. I just installed a completely new head that they sent me. I can't see any difference in the head.
However, I believe that the clunking is from the slight bit of play at the pivot point of the hitch head to the hitch frame itself. There is a large, about an inch in diameter bolt, that actually holds the entire hitch head to the frame and allows it to pivot side to side.
If you grasp the hitch head and push/pull it fore/aft, even though it is slight, the movement creates a clunk.
So today while installing the new hitch head Hensley sent me, I installed a bushing that took the gap out of the area where the play. I greased it up, slipped it in and there is NO more fore/aft play.
I feel confident that this was the problem as I've never such an issue prior to this set-up.
Good Luck, Phillip
Sounds like it may be necessary to re-engineer what is I believe a fairly pricey hitch. So far I'm not impressed with what I've been reading on this thread and elsewhere about this Hensley hitch.
I did a lot of research before I got the BD 3 and any air ride hitch is pricey. The BD3 is not as bad comparatively speaking. I did not find much in the way of "bad press" on any of the air hitches but there is always going to be problems with mechanical things. I got mine this spring and have put about 8K miles on it. My opinion is it is as easy to use or even easier to use than the B&W I replaced it with. Hook up is always positive and solid. With the jaws locking automatically like they do there is little to no chance of dropping the trailer on the bed, which is a feature I really liked on the B&W.
Where it makes its money in the towing. We did a 6 week, 4800 mile trip this fall and hit some amazingly bad roads. Watching the truck and trailer move independently of each other and not feeling the trailer movements made my wife a happy camper. I set the pressure in the bags before we left home and never had to make any adjustments on the entire trip.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
