avvidclif1
May 14, 2016Explorer
The easy way doesn't play well with my Curt hitch. If you do it the easy way the trailer stays level, just nose high. No problem for the Level-Up system as Rusty described. BUT my Curt wants the TV and 5er tilted the same, side to side, in other words the hitch and pin at 90 deg angle. I found if I go into manual mode and retract the rear all 4 rear jacks will go up. I then turn it off and back on and push the L+R buttons and the nose raises to the hitch position BUT without the rear jacks it will be tilted same as the ground and the TV. No problem hitching then.
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
