laknox
Jan 23, 2018Nomad
JIMNLIN wrote:Basically the same thing I have read all over the internet. These actually have quite a bit more load range than an LT in the same size.
We don't have a real heavy trailer and don't do real long trips, so I'm not worried about them whatsoever. I do plan on getting a TPMS system to go with them.
All ST tires have more load capacity the a same size LT tire.
However that in itself doesn't mean much as far as long term reliability which is one of the bigger reasons many trailer owners (rv and non rv ) use a LT class tire that meets the trailers axle requirements at a minimum.
Good idea on a TPMS system if running a ST E/D/C poly carcass tire.
ST tires simply have close to zero "reserve" capacity, they just rate them right to the edge of their design. LTs, since they are passenger rated, have a safety "reserve", which is, more or less, a down-rating of their max design capacity, to give more "reserve". I was told decades ago, by 3 or 4 auto-engineer types (mostly from the GM Proving Grounds) that passenger tires have about a 25% "reserve" load capacity over the sidewall rating.
Lyle
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
