Nevadastars's avatar
Nevadastars
Question going from 15" to 16" tires
I will be upgrading to 16" but am a little concerned about distance between the front and rear tires. With the current 225/75/15's, I have roughly 4 1/4" clearance between the tires. With 235/85/16's I figure there would be 2.5" which doesn't seem like very much.
There is also the 235/80/16 size which is not quite as tall and would have about 3.4" of clearance. I prefer the taller size because the trailer is a little nose high with the stock tires and the 235/85's would help level it. What is the usual clearance with that size tire/wheel combination. Thanks for any help.
  • You might want to consider 245/75R16 tires. The additional 10mm width gives you a little more contact patch without increasing the diameter.
    (Load Range "E", of course.)
  • Me Again wrote:
    Dexter spec is 1" or more. For LT235/85R16E's you need axles that are 33" center to center of more. That is the best measurement to go by. That says that you have the clearance above the tires also. Chris
    Just went and measured mine and they are 32 1/2" center to center. But from what everyone else said, I should be fine.
  • No issue between the tires, but like Chris mentioned, you need to also look at clearance between top of tire to wheel well. Best to maintain 2+ inches there.
    Jerry
  • donn0128 wrote:
    I have less than 2 inches. Been that way for the past 12 years with no issues
    Cool, that's all I need to know.....thanks.
  • Dexter spec is 1" or more. For LT235/85R16E's you need axles that are 33" center to center of more. That is the best measurement to go by. That says that you have the clearance above the tires also. Chris
  • I have less than 2 inches. Been that way for the past 12 years with no issues
  • Well let's put it this way .....if your tires grow 1 and 1/4 inches in use.... you better patent them and sell them.....:W
  • azrving wrote:
    All that matters is that they don't touch.
    Ok, that is what I assumed, but really have no idea how much they "grow", if at all. Thanks for the quick reply.
