MFL wrote:
I don't do much actual maintenance to either. I think the important thing for the fridge, is to have it level during operation. I do run the furnace after wet/rainy periods to dry it out, if it appears to be wet in the exhaust area.
I put screening over fridge and furnace vents during times of lots of bugs, but only when not in use. I have a piece cut for each, that I just tape on. I use screen just like you have in the screen door.
I think the best upkeep for these, is using them, rather than non use.
Jerry
The screening over the outside vents/panel areas is a good idea. In the springtime, I always open the outside access doors and make sure mud-daubers or other critters haven't tried to set up housekeeping.
Rob
