- dkreuzenExplorerJust an FYI, The first oil change on a 8000 diesel is at 50 hours...
- Sam_SpadeExplorer
hostage wrote:
so it pointless to change oil just because a year has lapsed
No sorry, it is NOT pointless.
If it was, the recommendation would not be there. - hostageExplorer
BobGed wrote:
Onan manual for my 10K genset is 250 hours or one year which ever comes first. I would imagine the 8K is the same.
250 hours seems logical but once a year is not I only maybe use mine 10 hours in a year so it pointless to change oil just because a year has lapsed - BobGedExplorerOnan manual for my 10K genset is 250 hours or one year which ever comes first. I would imagine the 8K is the same.
- doc_brownExplorer
2oldman wrote:
K Charles wrote:
x2
As often as the Onan manual says to.
X3. Don't forget the 1,000 hour big service. - KOExplorerI change oil and filter every year. I run my generator constantly while going down the road to run AC and wife using computer for work. It is an easy job and I do it myself.
- Sandia_ManExplorer IIWe change oil annually on our gas Onan when prepping and de-winterizing our rig for the first trip of the season. It only takes a couple of quarts and have always used synthetic over the last decade. Our Onan has just over 1K hours and is a decade old, I guess we change oil roughly every 100 hours.
- hostageExplorer
wa8yxm wrote:
Onan suggests fairly frequent oil changes..
Now first: YOU should run the thing for at least 1/2 hour under 1/2 load every month.
I would change at least every oil change for the Motor home if I were you. . However as I said. Onan may ask for more frequent.. and void your warranty if you don't.
warrenty at almost 8 years old? - wa8yxmExplorer IIIOnan suggests fairly frequent oil changes..
I would change at least every oil change for the Motor home if I were you. . However as I said. Onan may ask for more frequent.. and void your warranty if you don't. - Mile_HighExplorerMine notifies me at 150 hrs as I remember.
38,782 PostsLatest Activity: Sep 18, 2026
