fj12ryder
Jul 23, 2013Explorer III
There's no way to say because there are too many variables. As an example: I have a 2010 Fuzion 383, if I put 1500 lbs. at a particular point in my garage I will lower the pin weight 40 lbs. Going by that I would have to put around 10,000 lbs. in the garage to change the pin weight 300 lbs. :)
It all depends on where in the garage you put the weight, where the axles are in relation to the weight, where the axles are in relation to the pin, whether it is a triple of double axle...you get the idea. Just too many variables to make a reasonable guess.
I would say you are looking at trailers that will put your truck over it's pin weight allowance. But then again 2100 lbs. seems a bit light for a ton truck.
About Fifth Wheel Group
19,038 PostsLatest Activity: Apr 24, 2026
