GrumpyandGrandm
Sep 07, 2014Explorer
Most RV tire issues are not due to where the tire came from, but from improper loading, under inflation and speed. 99% of all ST tires (US made included) are speed rated at 65. As to using LT on a tandem axle set-up, it is not recommended due to the side wall flex in hard turns. LT's have been known to pop off the rim in a hard turn due to the stiffer sidewall. The other big issue with ST tires is how long the unit has sat on a dealers lot (usually gravel) without moving before it is sold.
We currently have a MH on a KODIAK chassis and it is governed very near 75 mph since the MICHELIN XZE's are speed rated at 75. So speed is part of the overall failure rate.
About Fifth Wheel Group
