GrumpyandGrandm
Sep 08, 2014Explorer
FROM RV TIRE SAFETY, just to mention one.
For Goodyear Marathon tires only:
There is a Goodyear Tech bulletin PSB#2011-13 that uses information from TRA.
The tech bulletin says that the normal max speed for Marathon ST type tires is 65 mph. This speed can be increased up to 75mph the inflation pressure is increased by 10 psi. This new inflation can be 10 psi higher than the pressure molded on the sidewall of the tire that is associated with the tire max load.
The load does not increase beyond the load molded on the tire sidewall.
Goodyear does not support or condone operation above 75 at any time.
The trailer owner is responsible to confirm the rim is rated for the new inflation level.
While TRA indicates a further increase in speed might be achieved Goodyear has decided not to adopt this option.
About Fifth Wheel Group
