dpgllg's avatar
dpgllg
Question on using auto level while stored for the winter
I have emptied and winterized my 5th wheel for the winter. It is in a storage yard with a gravel base. I used the auto level system and it is level so all four jacks are down and are on those orange leveling pads.
My question is should I keep the rear jacks down or not?
I'm going to cover it as soon as the cover I ordered arrives this week. I'm thinking that I may want to make it nose high so the rain and water run off a little better.
Your thoughts?
Dave
  • memtb wrote:
    If level when on the jacks, the roof “should” be designed to drain the water! memtb
    I can't think of a single RV built in the past 20 years that doesn't have a crowned roof. That said, a couple inches nose high can't hurt, but likely isn't necessary.
    Lyle
  • If level when on the jacks, the roof “should” be designed to drain the water! memtb
  • If assuming your slides are in and your trailer has the arched roof, there is no need to park it nose high. If it's a flat roof, then it won't hurt anything to keep it slightly nose high.
    Personally, I'd go ahead and level and keep jacks down. Your front jacks are down all the time already, aren't they? They are no different then the rear or middle jacks.
    Keeping the trailer level as possible is really best for the camper. With jacks down and level because you have multiple points of support occuring on the camper. Depending on the weather in your location, this is best for high winds and / or driving rain. The more points of contact to the ground, the more stable the trailer is. (granted, there is such a thing as too high a wind that could turn over ... even a semi-truck).
    When you are parked in a campground, do you not have the trailer leveled and all jacks down? What's the difference between storage or a campground? None.
  • It isn't an issue of weight on the jacks so I'd go with the nose high approach.
