bpounds
Mar 16, 2017Nomad
Get yourself a clear plastic elbow to attach between your drain hose, and the discharge pipe. Then test the flow from all of the sources as said above. If you had the clear elbow, it would have been obvious which one was the black tank contents.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
