jimmyfred
Jul 25, 2016Explorer
..........You might also consider an inside unit that exhausts the hot air out through an existing window ! They come in several sizes , but I wouldn't buy anything less than a 12,000 btu. The cheapest way is to simply install a window unit if it will fit into any of your exist openings . A place called Air and Water sells several brands of the inside units , they will run from 400 to 600 depending . , jf
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
