BarneyS
Jul 26, 2016Nomad
jimmyfred wrote:
..........You might also consider an inside unit that exhausts the hot air out through an existing window ! They come in several sizes , but I wouldn't buy anything less than a 12,000 btu. The cheapest way is to simply install a window unit if it will fit into any of your exist openings . A place called Air and Water sells several brands of the inside units , they will run from 400 to 600 depending . , jf
My son installed one that he purchased at Costco for less than $300 I believe. It works very well in conjunction with his roof mounted air conditioner in his Outback 30 foot trailer. He has it in the slideout and discharging out the side window.
Barney
About Fifth Wheel Group
19,035 PostsLatest Activity: Mar 21, 2026
