- Me_AgainExplorer III
Lantley wrote:
nickthehunter wrote:
So you rear end someone at a stoplight and the guy claims whiplash. How is he going to prove you were overweight?
It's not Rocket science. If your towing a 15K GVW trailer with a 3/4 ton truck. They can make the case you were overloaded. It's civil court.
They read the statement from the manufacturers concerning exceeding GVW and GCWR make their case.
Rear Axle might apply to federal bridge regulations but civil court will be a different matter.
I don't know your old 2007 looks pretty overloaded with that large Openrange trailer. 1-800-LAWYER - LantleyNomad
Rear Axle might apply to federal bridge regulations but civil court will be a different matter. - nickthehunterNomad IIISo you rear end someone at a stoplight and the guy claims whiplash. How is he going to prove you were overweight?
- CWSWineExplorerThis is how I come to my conclusion of not exceeding GVWR.
Here is what it says in the owner manual and tow guides.
“Note:
Trailer tongue (trailer king pin for 5th-wheel towing) load weight should be 10% (15% for 5th-wheel towing) of total loaded trailer weight. Make sure vehicle payload (reduce by option weight) will accommodate trailer tongue (trailer king pin for 5th-wheel towing) load weight and weight of passengers and cargo added to towing vehicle. Addition of trailer tongue (trailer king pin for 5th-wheel towing) load weight and weight of passengers and cargo must not cause vehicle weights to exceed rear GAWR or GVWR. These ratings can be found on the vehicle Federal Safety Compliance Certification Label.”
Towing Guides
Next I contacted GMC Commercial Sales and ask about exceeding GVWR and loaded to GAWR and they sent me this link and this is the GMC official position.
GMC Understanding GVWR
I believe that there is very slim chance that you going to get ticketed for being over your trucks GVWR of even the GAWR/GCWR/tire ratings. My research turned to the legal side started at the link below.
“Towing in excess of the vehicle manufactures’s weight limits could not only prove dangerous but could be considered negligent In the event of an accident with an overweight personal vehicle, you could be held responsible for higher awards in a lawsuit for damages to other people, vehicles or property.”
Link: Personnel Liability for RVers
Still not total convinced I made an appointment with my trusted family lawyer and he explained how manufactures specs on all kinds of products are used in civil court to gain higher awards and there doesn’t have to be a law prohibiting exceeding manufacture specs to play a role in court. The other question you might want to ask is what happens if a lawsuit exceeds my limits on my insurance policy and how to protect yourself. That question can’t be answered unless someone knows what assets would be exposed and what’s your income level. That was an eye opening meeting.
This is where my research led me and now I’m going to called the weight police and attacked. Your research may lead you in a different conclusion. Everything in life has risk but you have decided if the rewards are worth the risk. In my case towing above GVWR was not worth the risk. - JIMNLINExplorer III
mod wrote:
Does that make them better than the members of RV.net or somehow superior. I think not. They can laugh all they want as they use up their trucks and roll down the road towing somebody elses trailer. I think it may be a bit different tune were they towing their own trailer with their family on board the tow vehicle.
Barney
Hey Barney...just for the record...commercial haulers and especially those who work the hotshot side own their own equipment (trucks and trailers). We run our equipment lot more miles of service than the vast majority pulling a rv several times a summer or year.
Many haulers take the family along. I Took mine when they were small mostly on short 2-4 day runs.
A one ton DRW pulling a 15k-25k loaded GN trailer in commerce isn't any different than pulling pulling a same 15k-25k lb rv trailer... or a 3/4 ton....or one ton SRW pulling smaller weight trailers.
The fun being poked at RV forums is more about all the silly comments being made about the civil lawsuit/lawyer talk scare tactic regarding gvwr or the the tire placard payload sticker. - Me_AgainExplorer III
CWSWine wrote:
You can believe or not but this is the other side and if you don't believe this talk to your personnel lawyer and make up your own mind. I did!
Towing in excess of the vehicle manufacturer’s weight limits could not only prove dangerous, but could even be considered negligent. In the event of an accident with an overweight personal vehicle, you could be held responsible for higher awards in a lawsuit for damages to other people, vehicles or property.
Personal Vehicle Towing Liability for RVers
There is a old story about a single lawyer in a small town going broke. A second lawyer moved to town and they both became wealthy.
You personally appear to be at some point been towing over the 10K GVWR of your F250, and should go buy at least a F350 SRW(appears you bought a GMC 3500 SRW). Which just reinforces the point of buying a 350/3500 and not a 250/250.
GD 310gk
UVW* 12100 lbs
Hitch Weight* 2350 lbs
GVWR 15000 lbs
Your profile however is a bit confusing as to what you currently have. Appears that you have a DP now. Got to watch those also, as some are overweight also.
It does look like you have been out helping the economy, which is good! - CWSWineExplorerYou can believe or not but this is the other side and if you don't believe this talk to your personnel lawyer and make up your own mind. I did!
Personal Vehicle Towing Liability for RVers - MFLNomad III think many forum folks have become better educated over the last several years, concerning TV weight issues. There are still some that don't understand the numbers, when these 3/4 ton truck threads come up. Often times, to make their point, they use legal issues as a scare tactic, even though they have less understanding of weight laws, than they do of a trucks capability.
A forum member in the towing section, was recently told, because of his payload being low, that he could not carry a FW pin wt of 1,600 or more with his 2018 F250 diesel. When adding his family to the truck it would have put him over the class 2 GVWR of 10K. This truck would not have even been close to RAWR/tire rating, towing a mid sized FW. He thanked a few posters that tried to help, before abandoning his thread.
Jerry - Me_AgainExplorer III
BarneyS wrote:
Me Again wrote:
That is the manufacturer talking, not the State or Feds. You do realize that those making money as hot shotters have a good laugh about the RV.net weight police?
Barney
The point is that they tow up to the legal limits routinely, which is much higher than the weight police here post here in RV.net.
Until one has hauled under the federal bridge weight laws commercially and licensed in a state according to that state's laws the rest is just a cloud of misunderstanding of the laws and rules.
No pickup truck licensed/registered in accordance with one's states weight laws, if they register tonnage, is going to get in trouble being over weight. - larry_barnhartExplorerMy guess is if GM wanted to up the 1000 Allison it will be a done deal.
chevman
About Fifth Wheel Group
