Old-Biscuit
Apr 02, 2018Explorer III
Rbertalotto wrote:You just need to weigh the rear axle of the truck in question, loaded to go, full fuel, people, hitch, gear in bed, etc. If your rear axle weighs 3,200, and your RAWR is 6,200, you have 3,000 lbs of room left for pin wt.
I don’t believe this is even close to accurate. The only weight you need to look at is on the drivers door jam. That payload weight takes into account brakes, tires and other options. The weight rating of the rear axle is not the limiting factor.
Actually the RAWR and Rear Tire Max Load Ratings ARE the limiting factors.
Stay at or under those ratings and you are DOT legal.
About Fifth Wheel Group
