philstat
Apr 03, 2018Explorer
Old-Biscuit wrote:
MFG GVWR and hence Payload which is a byproduct of that MFG GVWR are warranty and vehicle registration numbers.
F/R Axles Ratings and Tire Load Ratings are DOT 'LEGAL' numbers
Any body can be hauled into a court of law over anything in a 'Civil' matter
but it's the DOT numbers that will get you into 'Criminal' matters.
In the end......
Folks need to use the ratings THEY are comfortable with
thanks for the post. Not knowing, bought 2015 HD 2500 Dmax. Sales guy said could "tow anything" Bought 5th with actual wet pin weight of about 2400lb. C sticker was max 2350 with my config. Added 5000lb air bags and researched axles, bearings, brakes between 2500/3500 silverados. All xact same. only diff was added leaf spring to 3500. Feel confident all is safe only worry is accident/lawsuit about c pillar sticker. You give me some confidence that all could be ok. not worried about capability any longer just legal stuff. thanks again
About Fifth Wheel Group
