Road_Phantom
Feb 25, 2021Explorer II
Ram 2500 only carries 2300 lbs.
My 2018 diesel Ram 4x4 2500 has coil springs front and back. I'm overloaded on my 5th wheel (2000lb hitch weight) and total GVWR by 800 lbs after everything is loaded up for travel.
My local spring guy claims a heavier duty coil spring upgrade would solve the overload problem, since everything else on the 2500 is heavy duty. I would like to know if anyone else did the same to their similar truck and recommend it. Thanks.
