Joeydrunk
Nov 08, 2016Explorer
Old-Biscuit wrote:
FIRST OFF.......
You need to clean that sooted rusted disaster up :B
Remove burner tube from gas valve and combustion chamber along with pilot flame tube and thermocouple
Remove exhaust heat shield
Clean burner assembly with wire brush and small bottle brush thru tube
Scrub exhaust shield clean
run a wire thru combustion/exhaust tube, tie rag on wire and pull it back thru several times to get soot/rust out
Reassemble
Loosen screw and move clamp back opening air shutter FULLY
Fire it up
Slowly move clamp closing off air shutter until MAIN flame is strong, steady blue flame with just a tinge of orange at tip. then tighten screw
Should be no more sooting going on
OR you may have to buy new pilot flame/thermocouple/burner tube assembly to make it work
Thanks, and I sorry it took so long once again. I did most of what you said, and I took off the black sheild and cleaned a **** load of soot out and adjusted that slider on the tube. I It's allot more noise but way less yellow flame and its been about a month and there no build u like there would have been. p
About Fifth Wheel Group
19,007 PostsLatest Activity: Feb 28, 2025
