ToddD wrote:
fallonator22 wrote:
our water heater may be frozen as well, our water pump also, and i dont know where TF either of those are. i am hating myself for not doing more research right now.
Yikes, how did that happen? You didn't run out of propane again, did you? (Sorry, bad joke).
Seriously, though, unless you turned it off or lost electric, how did your hot water tank freeze? Is it a tankless system?
if the water heater is electric, it may be frozen. i turn on the pump because i was thinking MAYBE we could fill the fresh water tank and run that, but when i click the button i can't hear it turn on as normal, so i'm assuming it's frozen. heat fan is in the storage underneath pointed at where the connections are. nothing seems to be helping. we still have propane. furnace is still running. nothing is changing and it is only supposed to get colder. i am kind of afraid of pulling the thing with all the bouncing with frozen sh*t in the black tank which is one of the reasons we haven't left yet. and we are hopeful i guess that things thaw out and we can use the water.
