bertrandExplorerJun 25, 2021hot water tankthere is air pressure in the hot water tank of my 5th wheel. when the city water is not connected and I empty the water tank and even when the relief valve is open the pressure is so stong it takes t...Show More
bertrandExplorerJun 26, 2021thank you Wildtoad and Old -Biscuit for your suggestions, I will try what you suggested and I also suspect that I may have a bad valve
Related ContentDraining hot water tankHot water tank drain plugHot water tankRecycling engine heat for hot water tankNeed help, hot water tank fail.
