OBX-GL's avatar
OBX-GL
Explorer II
Aug 02, 2021
Need help, hot water tank fail.
Ok, so DW wants hot water while off grid. Unreasonable right ? :)
Hot water tank works on shore power, but only kinda on DC.
Basically it cycles ignitor/clicks normally. It fires fully on very very first ignition click, full flame stays on as long as ignition clicking keeps it going. Issue is, it goes out with the end of ignition cycle. Again back on first click for remaining two cycles till system times out. I'll turn off/on the switch and the same symptom persists again for that cycle.
Not sure of the brand of unit. I have vacuumed out what i can, no change. Seems to be very little to adjust, or clean, or take apart. I don't even see an adjustment on the tube to alter fuel/air mixture.
I'm the original owner. It did work when last i used the propane option, that was many years ago however.
Please add your thoughts !
- Greg
