- JRscoobyExplorer II
95flhr wrote:
ivbinconned wrote:
Well I got the bottom off. Thankfully it’s not the tank but the plastic nipple that screws into the tank for the drain. There is about 5 inches of plastic water pipe down to the valve. Stupid of Forest River to not use copper for something very exposed to the elements.
Copper is not a good choice for some water chemistry. I know it’s not allowed here for houses on well water, as the water will corrode it pretty quickly.
I can remember when trucking industry used copper for air lines; From that experience I would not want to use for water on a vehicle.
Best bet would be to replace it with pex line. It rigid yet flexible.- 95flhrExplorer
Copper is not a good choice for some water chemistry. I know it’s not allowed here for houses on well water, as the water will corrode it pretty quickly. - LantleyNomadUnless the tank has been struck or damaged somehow the problem is seldom the tank, but more often the associated plumbing, like valves , nipples and fittings.
- ivbinconnedExplorer IIWell I got the bottom off. Thankfully it’s not the tank but the plastic nipple that screws into the tank for the drain. There is about 5 inches of plastic water pipe down to the valve. Stupid of Forest River to not use copper for something very exposed to the elements.
- BemotaExplorerMy ‘18 the tank was fixed twice and leaks again now have to tear it apart and see why I flooded the lot the last night we used it Dan
- ivbinconnedExplorer IIIt ran completely dry dry fast so I doubt that it is piping.
I know I’ll be smarter when I have the panels off.
My question was about using aluminum to build another one. I thought perhaps that would be ok since the hot water tanks are aluminum.
Plus the benefit of having a bigger one. - LantleyNomad
bucky wrote:
I suggest dropping the underbody and seeing what's going on before you order an expensive tank that may not the problem.
This is good advice. You don't know that the problem is the tank itself.
Problem could be a fitting or piping leak. - midnightsadieExplorer IIgee mines 17years old still going strong, might be a broken line etc.
- buckyExplorer III suggest dropping the underbody and seeing what's going on before you order an expensive tank that may not the problem.
About Fifth Wheel Group
19,041 PostsLatest Activity: Jun 18, 2026
