Thanks for the reply, and the heads up,seems every brand has some loose ends these days. Dweller I see you are also in Pittsburgh, what dealer are you using for service? I figured the hitch weight is heavy, I think brochure says 1300 pounds, luckily my primary tow rig is a ram 5500. The TH I built was way tongue heavy, i added air bags to my 2500hd, then again solid oak doors, flooring, trim and cabinets will do that hahaha. I used to ***** about how thin something's in RVs were then I realized being cheap wasn't the only reason for the thin doors and panels, they saved a lot of weight. Thanks again
