way2roll
Dec 22, 2022Trailblazer
CoMoCo wrote:
Why has it become out of level? Have the jacks sunk further into the ground?
Lots of reason why they get out of level. Ground movement, temperature changes, settling, jacks letting off a bit of pressure. I don't think I have ever owned an RV that didn't get a bit out of level after some time. Rigs with full walls slides can get out of level after a day just from having all that weight on one side - especially if you aren't on a paved surface. dramatically out of level could be indicative of an issue, but a little bit I would consider normal. Even stick and brick houses get out of level with settling and freeze/thaw cycles.
Hopefully the OP returns to the post.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
