fj12ryder
Dec 22, 2022Explorer III
"Manually leveling does NOT create binding of any type." And you know this how? Or just what you think? If you raise just the right rear side, which would be the middle and rear levelers, and not the front, what happens to the right front side? Won't it no longer be supported as much by the leveler at that corner?
I believe the hydraulic cylinders are rated at 8-10,000 lbs. EACH. So it would seem pretty unlikely you'll overload 50-60,000 lbs. worth of hydraulic cylinders. And can't see how manual level would be any different, the pressure is always the same.
I can't personally say whether it will recycle when AutoLevel, but have heard that it doesn't. But cannot say for sure, I've not done it when level so can't say.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
