fj12ryder
Dec 23, 2022Explorer III
Cummins12V98 wrote:Well, maybe yours does that, but my front levelers are completely independent of the center/rear levelers when in Manual. If I raise/lower the rear of the trailer, the center and rear levelers move, the fronts do not. It's best not assume that because yours works that way, "They all do that". :)
I know this because I have extensively had conversations with Melvin at Lippert on how the system works. The fronts adjust to what you do at the rear on each side. Have someone hit extend off door side rear you will see the off door front extend. The side levelers are tied together and balance them selves also.
The front drops when you hit auto level, you can't stop it. I guess all I can say that is how mine has worked in the past as I am not using auto again. So if you are slightly out of level after setting for a while go to manual mode and adjust to level it's that simple.
I don't know "Melvin at Lippert" but bad/wrong advice coming from the builder/factory is not unheard of.
About Fifth Wheel Group
19,042 PostsLatest Activity: Dec 14, 2025
