Likes_to_tow
Aug 23, 2024Nomad
No flow from hot water tank Nautilus P1 system
No hot water Our 2017 27RL Reflection 5th wheel has the Nautilus p1 water distribution system. Once last year and then again a few days ago after filling the fresh water tank we had absolutely no ...
- Aug 31, 2024
UPDATE ON PROBLEM....... The check valve on the outlet port of the hot water tank has failed. The spring is missing and presumably rusted and now probably inside the tank. When the spring is missing the plunger on the check valve will block flow from the tank preventing any hot water supply. Easy fix and available at Amazon.
