2112 wrote:
Ocationaly I have to use two 30 amp cords together to get the length I need but where that conection is made I have no problems.
Is this 1 of those occasions?
How long is this extra cord?
Are you running the AC for extended periods while using this extra cord?
Did you measure that 110V inside the camper or at the shore power connection?
Is it time for more detail or shall we just keep slinging feces?
No only one cord. The voltage in the camper was about 112 or a bit higher at the lowest. Anything lower than that I shut the ac down.
Yes the ac was on quite a bit. Oh I forgot only one AC unit. Nothing else with a major draw was on. Yes the standard stuff that the camper pulls just sitting there and the refrigerator. No hot water heater, microwave or even the tv are on with the AC. I know the TV doesn't draw that much. If I need the microwave or hot water heater the air goes off. Only one of these a time.
All cords ae about the same length. I think the normal length is 25"??
I personally think its the connectors. I changed them out a year os so ago and this is the second one that needs to be replaced. I can see the plug going into the shore power occasionally burning becaset their receptical is just wore out and not making tight connection. These are new Camco connectors. The female going to the 50 to 30 pigtail is the one that is bad this time again. I will have to replace the male pigtail and the female cord connector this time.
