librty02
Oct 01, 2019Explorer
Re: Question for those pulling with an F150 Eco Boost
Likes to tow wrote:
I have seen some folks pulling small 5th wheel RV's with the F150 Eco Boost and wonder how well these engines hold up over time. Seems like everyone says the torque is there when needed and it does a decent job but my question is how long will they hold up?? It would seem that screaming an engine under boost would make it wear out quicker. How many miles have any of you accumulated with your Eco Boost??
I've been towing with a 3.5 eco since 2011 and it is the best gas towing engine I've ever had. Have over 100k on the 11 with at least 50k of that being towing and a newer 18 3.5 with 14k on it with 8k towing on it so far. The engine does not scream per say as it is almost silent while even towing up 77 in the blue ridge mountains 65mph 7th gear at 2200 rpms....as it has been and is a great engine it tows my 7000lb travel trailer very well and with ease. With that being said half tons are known for their lower payload numbers. I have 1801 lbs of payload with my '18. With the 7000lb trailer connected my wife, daughter, dog, and I in the truck with only a few lighter things in the bed we are near the trucks GVWR. I would not even think about towing a 5th wheel with the 150 unless it had the max tow and the heavy duty payload package to give you a payload north of 2200lbs and a heavier 4800lb rear axle rating. Could that V6 pull a 10000 trailer yes it can no problem at all but even a 7000lb fifth wheel could have anywhere from 1400 to 1750lbs of pin weight alone. So take my truck with 1801lbs of payload that 7k 5th wheel could leave me with only 51lbs of available payload left meaning I couldn't even get into the truck and drive it without being over the trucks GVWR. The HDPP 150 will give you more wiggle room with that 2200lb payload but you would still have to watch the weights. Even a 3/4 ton diesel may not work as I have seen their payloads range anywhere from as low as 1700lbs to 2500lbs. You have to choose the exact trailer you want 1st and then go get the truck needed with the capacities to tow it.
