dvg84x
Oct 30, 2013Explorer
On my '07 3814, I had the same problem with my single slide. The "breaker" is only 30 amp rated, which seems like it is just enough when the unit is new. I replaced it with a 40 amp and no problems since. The breakers are available at truck stops or truck supply stores. Take your old one with you to get the exact style.
My single slide has had a squeal (metal to metal) since new and no amount of lube (as far as I can get in the telescoping arms) has solved it - works fine other than that.
About Fifth Wheel Group
19,031 PostsLatest Activity: Dec 16, 2025
