Marc2007
Aug 27, 2015Explorer
RustyJC that is kind of the solution I was going to use. There is no bottom plate. The steel frame is flat in the rear and the wall sets vertically against it. They drilled holes in the steel frame and used 4 small self tapping screws screwed into the 1/4" paneling to hold the wall to the frame. I am going to drill through the fiberglass and the metal frame and use the carriage bolts through the whole assembly. That way the screws cant pull out of the paneling again.
It looked like an expensive repair when I first noticed it.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 24, 2025
