tmm2good
Feb 04, 2018Explorer
fj12ryder wrote:
Kind of looks claustrophobia causing though, only a little over 2 feet to the ceiling with the bed down. It would give you enough room for the bike though. The loaded weight could easily hit 16,000 lbs. considering shipping weight is over 13,000 lbs. That shorter ramp/door could cause loading issues too. Even the picture they have of it shows a pretty steep angle.
We looked at the high country at the Denver RV show last month.
A little claustrophobic in the garage, but you are just loading or unloading the bike in there and then you are done. The ramp angle is about the same as the Momentum we just ordered, and it will be way easy to load a bike, easier than our current toyhauler with the garage on top of the frame rails instead of it being between the frame rails like these models.
About Fifth Wheel Group
19,006 PostsLatest Activity: Jan 13, 2025
